98 LS1 and 99-02 LS1 what are major differences???
Old Apr 28, 2006 | 10:45 PM
SDMForever's Avatar
Default 98 LS1 and 99-02 LS1 what are major differences???
I have been told that the 98 LS1s are very hard to make good hp as compared to later years. I was wondering what are the differences and what are the ways people are fixing them?
hmmm........
Old Apr 28, 2006 | 10:49 PM
steveb's Avatar
I would have to say the heads are a big limiting factor.
Steve
Old Apr 28, 2006 | 11:35 PM
SDMForever's Avatar
That is a big issue... so all of you that have 98 heads get some patriots or some 99-02s.
Old Apr 29, 2006 | 12:21 AM
pekkaz's Avatar
There is difference in stock head flow characteristics between years but I doubt it's worth much more than 5 hp.
Old Apr 29, 2006 | 01:00 AM
jermzz's Avatar
ls6 intake too comes stock on 01 an 02
Old Apr 29, 2006 | 01:10 AM
HottLS1Z's Avatar
Its not harder the heads flow so similar its worthles to compare just the they have different valve cover bolt patterns and the 98-00 have the LS1 intake. A 98-00 Fbody with an LS6 intake is faster then a 01-02 all other things even cause they had a bigger cam I know this from personal exp too, I have one and it now has over 128k on it with the stock oil origional oil pump, and all origional interrnals except springs, and many 150 dryshot nitrous passes on it still runs strong and doesnt burn anything. All those rumors about 98's being "Bad" are very annoying to me. My .02
Old Apr 29, 2006 | 11:33 AM
ynneK's Avatar
about 99 and up they put better bay windows in the block for better oil control down below..
I think they changed the rod bolts also around that time.
Old Apr 29, 2006 | 01:35 PM
steveb's Avatar
Not shure wat its worth on a stock car but Slowhawk did the same cam and mods in a 98 and 99 and you could tell by the graph where the 98 heads were holding it back. I think it was 20hp and 15ft.
Steve
Old Apr 30, 2006 | 09:39 PM
SDMForever's Avatar
What about PCV?
