pulling and checking pushrods?
Old Apr 29, 2006 | 01:07 PM
dZ28adams's Avatar
Default pulling and checking pushrods?
im pretty sure i bent another pushrod ...last time my car was under warranty so i didnt have 2 mess with it but this time i will. so how hard is it 2 pull and check ur pushrods? and what all has to be removed?
Old Apr 29, 2006 | 02:18 PM
vodas00ss's Avatar
pull your valve covers, and pull your rocker arms off, once your rockers are off your push rods are right there. nothing to it at all. You will have to tourque your rocker arms back down, so make sure you have a tourque wrench.
Old Apr 29, 2006 | 02:21 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Yeah just get the rockers off then pull the pushrods out.
Old May 3, 2006 | 03:32 PM
italianone's Avatar
How much tourque is needed for the rocker arms on stock.....
Old May 3, 2006 | 03:34 PM
'02 SLP#686's Avatar
22ft/lbs - Should run them down to 0 lash and go to 22ft/lbs without going over 1.5 turns
Old May 3, 2006 | 03:35 PM
italianone's Avatar
SO that works for a 1999 z28 right? I only hear the tick tick tick sound when I am to low in a gear only. Does that mean i have a bent rod or rods????
Old May 3, 2006 | 03:45 PM
italianone's Avatar
