HOLY SHEET!!!! H/C car with problem
Even if you do, (for some reason I don't know), you'll probably LOSE fuel economy.
What, to save $2 per tank of gas??
when you use a hand held programmer it changes (as most know) the fuel and spark curve and it says (if it doesn`t have have dual fuel grade tuning) to not use lower than 91 or as a hyperteck if I`m not mistaken 93 octane or detonation (some noises might be heard and shakes felt) due to the reprogrammed computer advanced spark that in many cases will not tolerate low octane fuel ....
bottom line ask PCM4LESS if the tuning was on 93 octane and running 87 MIGHT be the problem .... just a thought.
(next time anybody does that with a 87 octane in the tank my advice take out the remaining fuel the old hose sucking way and fill it up with 93 or what it was tuned on)
hope it helps.
No coolant in the oil, probably a head gasket. I just hope the heads and block are ok. It only ran about 3 miles to get home. I'm going with ARP head studs or bolts this time. If I cracked the block on the install it would be losing coolant into the oil correct?
No coolant in the oil, probably a head gasket. I just hope the heads and block are ok. It only ran about 3 miles to get home. I'm going with ARP head studs or bolts this time. If I cracked the block on the install it would be losing coolant into the oil correct?You may have had some detonation though, and that would explain the failed head-gasket.
Make sure you get your block and heads re-decked flat before bolting it back together.
I like 87 octane myself, but I'd suggest draining your tank completely before running the car again. Use whatever is in your tank for the lawn-mowers.
Put some Amoco ultimate or Shell V-Power both 93 octane, but the only fuels I burn.
