going to buy dart heads but have a question
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
i was thinking about buying them bare so i could put dual springs on them. but which dual spring will go right on the with no work done. and where can i get valves for them?
or should i buy complete heads and just sell the 918 springs that come one them.
First, they don't come with 918's. What is your spring requirement for lift? The out of the box setup is hard to beat, the springs are beehive PSI springs with titanium retainers and machined locks. The valves are drop forged and are pretty light, 98 grams for the intake.
If you buy the heads complete and are very careful on disassembly, I might be interested in the Dart springs and retainers you remove. The springs are nitrided though, so you can't scratch them. You must use a spring tool that pushes down on the retainer like the big "C" clamp type of tool.
https://ls1tech.com/forums/generation-iii-internal-engine/437768-dart-heads-just-have-let.html
This should help you out a bit
Originally Posted by CHRISPY
They are 918 springs. Dart buys the springs from the same supplier that sells them to Comp OEM
