Got my motor together...almost
-2002 LS1 block bored to 3.908 bore
-Mahle forged flattops with 4cc valve reliefs
-Callies Compstar rods with ARP 2000 rod bolts (6.125")
-Polished stock crank
-TREX camshaft (243.4/249.1 .613/.619 110 lsa - actual specs)
-LPE CNC ported hand finished heads with Manley 2.02 int. and 1.575 exh. milled 0.070
-Comp OEM replacement lifters (850-16)
-Stock rockers, PRC dual springs, Rollmaster double roller
-Powerbond 25% underdrive pulley
The only problem is figuring out pushrods. The base circle on the cam was around 1.47 so I would need a little more than stock in that sense, but the heads being milled 0.070" the pushrods need to be shorter. I have no PTV clearance problems with the valve reliefs, but trying to measure preload on a hydraulic lifter isnt very accurate b/c you dont know how much the lifter is making up for. I put a stock pushrod in and torqued down the rocker and turned the motor over by wrench on the balancer bolt, and that told me nothing about whether or not stock pushrod length was too much or not. WHAT DO YOU GUYS THINK??
