Why would one bank run lean??
Old May 1, 2006 | 03:30 PM
muncie21's Avatar
Default Why would one bank run lean??
I've noticed hesitation during part throttle acceleration. Looking at the wideband it appears that bank 2 is running lean (16-18+AFR) during this time. Here's the kicker...it only does this from 2000-2100 or so RPMs.
I'm thinking, either I'm losing fuel at that point or I'm getting an air leak. I swapped the injectors from side to side, to eliminate them. Can't figure out how an air leak could come and go.....ideas???
Old May 1, 2006 | 04:36 PM
bichin95redta's Avatar
The only thing I can think of, is the cam sensor. A few important functions of the cam sensor:
detect misfires
determine which half of the engine's firing sequence is currently in operation
Old May 1, 2006 | 05:25 PM
Rescue Ranger's Avatar
reminds me of a stupid line from 'gone in 60 seconds' - Angelina talkin about a guy riding his brakes and nick cage comments saying "sounds like the left bank is runnin lean.' Yea sorry I know that wasn't helpful..
Old May 1, 2006 | 05:39 PM
muncie21's Avatar
Made me laugh though. At least I 'know' it is running lean, and not from listening to it
Old May 1, 2006 | 05:44 PM
TAQuickness's Avatar
get some starter fluid or carb cleaner and spray around the intake ports. I'm working to resolve a leaky #7 intake port gasket. Same symptoms you described.
Old May 1, 2006 | 06:18 PM
whiteLS1's Avatar
bad injector possible.
Old May 1, 2006 | 06:24 PM
muncie21's Avatar
Swapped injectors, side-to-side. Lean issue didn't follow the injectors, so I don't think it's that.
I'll check for a leaking intake gasket.
Old May 1, 2006 | 08:21 PM
JL ws-6's Avatar
Race your car!
bad 02 sensor?
Old May 1, 2006 | 08:56 PM
muncie21's Avatar
Originally Posted by JL ws-6
bad 02 sensor?
No, you can feel the hesitation when it leans out. Also, I double-checked my wideband with the dyno wideband when I was on the dyno recently.
I'm thinking it's a leak, but what leak can come and go at a specific RPM?
Old May 1, 2006 | 08:59 PM
97blkz's Avatar
Check your wiring harness for shorts, mine burnt and caused this.
Old May 1, 2006 | 09:34 PM
whiteLS1's Avatar
switch the coils and see if that changes where it is lean. that would be my next step
Old May 1, 2006 | 09:40 PM
muncie21's Avatar
hmm, hadn't thought of that. Pretty easy to do, I'll give it a shot. Thanks
Old May 1, 2006 | 11:10 PM
Quik's Avatar
simple one, had a problem like yours, ended up cracking 2 of my plugs some how.
Old May 14, 2006 | 07:10 PM
muncie21's Avatar
OK, figured out that I've got a leak on the passenger side intake. Now the question is, how to fix it? I've already tried replacing the intake gaskets (both sides) with new ones. Re-checked the torque also. I'm wondering if I've somehow got a warped intake on that side.
BTW, it's a maggie (intake is part of the blower) so getting a new intake could be a costly proposition.
