Hole in block?
Old May 2, 2006 | 02:21 PM
King James's Avatar
Default Hole in block?
Getting my car torn apart for a upcoming cam swap and found this last hole in my block last night. Its on the passenger side of the block and the hole goes straight through the webbing. I don't think it is going to cause any problems (hasn't in 80k miles), just figured I'd show you guys and see what anyone had to say.
Sorry they aren't the greatest. I didn't have my digi cam with me last night.
Old May 2, 2006 | 03:44 PM
SUTTERERMAN85's Avatar
huh thats wierd... never seen that before. maybe just a flaw in the casting. if its just in the webing id say you are ok. its not cracked anywhere around then id wouldnt worry about it.
Old May 2, 2006 | 03:47 PM
onelife's Avatar
If you can't have it welded just drill and tap a hole to plug it up.
Weird though.
Old May 2, 2006 | 04:31 PM
King James's Avatar
I figured its just in the casting. There is no oil residue or signs of coolant leaking out there so I'm not real worried about it. I just hadn't seen anyone mention something about this before so figured I'd post up.
Old May 2, 2006 | 06:15 PM
kossuth's Avatar
Nah, won't hurt anything at all. It's not even close to anything important.
Old May 2, 2006 | 06:18 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Looks normal to me. I've seen that quite a few times, if not on every motor.
Old May 2, 2006 | 11:46 PM
eallanboggs's Avatar
The hole looks too symetrical to have been caused by an engine failure. I don't know if the block was sand cast or used the lost foam method, but it could have been something in the mold.
