N/a Or Turbo
My choices are either all motor 427 making about 600rwhp, and a 200+ shot of nitrous. Or the other option would be with forged internals on a 346 (maybe 383) with a turbo setup. either way I am looking for 800+ rwhp, but I want to get there with the least amount of money spent.
suggestions.
[QUOTE]300bhp/ton If you don't want to pay don't play, it's that simple
I want to play and I know I have to pay, but figuring out which one costs less is Ideal...
Do you already have a suitable chassis for such a power plant?
What sort of fuel are you planning on running?
What's the car going to be used for primarily?
600rwhp n/a is going to be one vicious race setup and personally I wouldn't have thought all that street friendly also a 200 shot is not a stroll in the park if you plan on using it regualarily.
A blown 346ci on pump petrol making 800rwhp IMO would be a tall order. Either way you could expect a large bill at the end of a nights use just for maintance and repair.
I would guess the more reliable setup would be a milder one, so maybe large displacement and FI with maybe a little nitrous on top for when you really need that extra 100bhp or so.
Either setup I think the potential cost is going to be rounded up to the nearest couple of thou so if you have that sort of money to play with I can't see it really mattering which is slightly cheaper, surley the best setup for your intended application is the way to go?
Anyhow good luck with your decision
To get a motor built to handle the boost and get a turbo system to support the power will cost far more than a nitrous setup. Either way I look at it to make the big numbers will require race gas, and will be horrible on the street. Either way I make the power there will have to be multiple settings for street and race. I already spoke with multiple engine builders for the 427 route, and 600rwhp isn't difficult. It will cost a few bucks and have a rough idle, as compared to a smoother running turbo setup. Either one at close to 600rwhp will have little traction on street tires, and N/A is noticably louder than a turbo setup.
You wont be disapointed if it is done correctly If you wanna go even further on a budget, I'd stick with a 408, go forged internals and spray a 200-300 shot.
you can get 550 rwhp out of an NA 408, then add a 200 shot and 750 rwhp and 800+ ft/lbs.
408's will be a couple grand cheaper then a 427 I believe.
I personally love my setup though.
