Is is possible for lifter to go bad.....
Old May 4, 2006 | 12:28 PM
TNTramair's Avatar
Default Is is possible for lifter to go bad.....
from being takin out and reinstalled??? put a set of heads on the car and when i got everything back together with new header gaskets/header band clamps/rocker preload set right (non-adjustable), there is an annoying tick which appears to be coming from driverside. my first impression from the sound would be a header gasket type noise, but they are bran new and have been re-torqued numerous times after cool down. so than a few people have mentioned lifters. i should have replaced them but since there wasnt a problem with them before i didnt think of it at the time. is it possble for 1 to go bad just from takin it out and re-installing??? im not losing oil pressure at anytime...car runs fine and appears to have plenty of power its just got this tick that annoys me and sounds like it will cause a problem if i let it go. its embarrasing cause it allmost sounds like a light valve tap. anyone run into this problem han can shed some light?? thanx
Old May 4, 2006 | 12:29 PM
TNTramair's Avatar
fyi....i did recheck all the plugs and wires...also the torque on the rockers...all were ok.
Old May 4, 2006 | 12:59 PM
King James's Avatar
Pushrods the correct size?
Old May 4, 2006 | 01:08 PM
TNTramair's Avatar
they are stock size from thunder racing
Old May 4, 2006 | 01:48 PM
daryl2cb@yahoo.com's Avatar
I guess you could have a bad rocker, or maybe it is not correctly seated on the valve, but lifters do go bad, stock rocker?
Old May 4, 2006 | 02:47 PM
TNTramair's Avatar
NO...yella terras.
Old May 4, 2006 | 03:13 PM
6spdpewterZ's Avatar
Happened to me. One of my lifters was bleeding down but it was due to bad oil pressure. Replaced oil pump and all went away.
