do you bend alot of pushrods?
Old May 5, 2006 | 01:40 PM
01Generalee's Avatar
Default do you bend alot of pushrods?
my car has bent them 3 times from over reving I guess. maybe the rev limiter got tuned out or something :dunno:
Old May 5, 2006 | 01:47 PM
Lithium's Avatar
SSU's Drunk Typing Whore
you been missing a few shifts lately? either way get some better pushrods in there.
Old May 5, 2006 | 04:57 PM
Zymosis's Avatar
Word, do any 3rd to 2nd shift at 6k recently...??
Are you using the stock pushrods?
Old May 5, 2006 | 05:00 PM
indyboom's Avatar
never bent one.. in any engine
Old May 5, 2006 | 08:34 PM
Sartobuilt's Avatar
Whart were the symptoms that lead you to the pushrod?
My '02 camaro m6 Is making noise and smoking , no loss in oil press. or missing. It just rattles real bad at an idle.
Old May 5, 2006 | 08:38 PM
nelson1100's Avatar
Default the drivetrain and belts etc..
can be noisy and the ls1 is famous for dumping oil in the exhaust,
Old May 5, 2006 | 09:52 PM
TA TECH's Avatar
Sounds like you need to upgrade your springs!When I run the crap out of my old car the stock valve springs where crap high rpms don't mix with the stockers I replaced all of my stock springs to ls6 springs and never bent another one put about 5-6 pushrods in with the stock springs!Ha anyone need some 500 mile ls6 springs, blue?HA!I Keep the stock pushrods with the new springs!
Old May 6, 2006 | 12:50 AM
67Ranger's Avatar
This is from a missed shift. It started to tick one night pretty bad, and then the one just broke, i guess, and it smoked, and missed pretty bad. It didnt tick untill about 2-3 months after it had happened though, but all of them were bent at least a little.
Old May 6, 2006 | 11:43 AM
1BADAIR's Avatar
DO NOT uprade the pushrods without changing springs. If you do the valves and heads will get damaged if you overrev again
