WTF is this in my oil?
Old 05-07-2006, 11:48 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
The rear crank seal doesn't have a spring.
Old 05-08-2006, 12:18 AM
LS1powerhouse02's Avatar
Originally Posted by andereck
Umm before you drop the transmission buy a timing cover seal. You've replaced the cam and that's what the spring is from.
well son of a bitch.....everytime i think i got it figured out someone else comes on here and turns it COMPLETELY around!
Soooooo.....what exactly is this spring from?!?! does anyone know for 100% sure and could anyone show me a picture of what its from. I have been researching my *** of for the past 2 days and i have gone from a ring, to a rear-main seal to now a timing cover seal. However thanks for all the responses guys! I just hope to have this all figured out sooner than later
Brent
Old 05-08-2006, 01:25 AM
SHINER's Avatar
I have oil residue on my plugs whats up with that? i dont burn much oil and get good gas mileage...what gives?
Old 05-08-2006, 06:26 AM
xaon's Avatar
run a compression test and pull the pan.
Old 05-08-2006, 07:53 AM
SHINER's Avatar
why do i pull the pan, what am i looking for?
Old 05-08-2006, 08:16 AM
andereck's Avatar
Go to the parts store and look at a timing cover seal. You can compare the spring you have to the spring on the timing cover seal. I think you'll then agree that's what it is.
Old 05-08-2006, 12:27 PM
so as i was sitting here studying for my final i started getting curious. I grabbed a stock valve stem seal that came out of my car before the cam swap. On the end of the seal was a spring, so i slipped the spring off and broke it just like the spring i found in my oil pan was broke. And here are the results.........
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Old 05-08-2006, 12:31 PM
when i installed my dual valve springs i was told to use valve stem seals from a 98-99 LS1 b/c they weren't molded into the seats like the 2002s were. (i couldn't use the stock seats with the duals). So my question is....how the hell did these seals with less than 10,000 miles on them bust when the stock ones lasted 75,000? Is the diameter of the valve stems larger on 02s than the 98-99s? i am going to pull the plugs and remove the valve covers to see where it came from when i get done with my final today.
Old 05-08-2006, 12:32 PM
andereck's Avatar
You wanna lay the spring down on a ruler for us?
Old 05-08-2006, 02:36 PM
FstBlkz28's Avatar
In the 2 cam installs I've done and the 4 timing cover gaskets I've had in my hands. None of them have had springs on them. I didn't see a spring on the front main seal either ... unless I just missed something all together.
Old 05-08-2006, 02:39 PM
BIG BAD BLACKSS's Avatar
Old 05-08-2006, 07:49 PM
  #32
Quickin's Avatar
Bro, its the spring that goes around the top of your valve before the main valve springs go on. I had 4 of those sitting around in my head when I took the valve covers off. It only has to do with the seal, it has nothing to do with dropping a valve.
These were my broken MAIN valve springs, the little springs you found are under the silver round spring retainer, you can't see them when the main springs are installed. Take that silver round retainer off and the little spring is wrapped around the tip of the valve.
https://ls1tech.com/forums/generation-iii-internal-engine/472364-5-springs-broken-good-thing-they-were-double-springs.html
Old 05-08-2006, 09:02 PM
  #33
https://ls1tech.com/forums/showthread.php?t=472364
i think you misunderstood what i said. I figured out what the spring came from finally this morning. I even showed some pictures a few posts up. I never thought it was the valve springs. I promise i'm not stupid but thanks for your help!
