LS1 factory rocker ratios
Old May 7, 2006 | 11:19 PM
rjgto's Avatar
Default LS1 factory rocker ratios
Anyone here measure their rocker ratios? - what did you come up with?
Thanks
Old May 7, 2006 | 11:22 PM
DEVIATE's Avatar
1.7 is the factory ratio
Old May 8, 2006 | 02:24 AM
RedLT4Mike's Avatar
Not advanced tech.
I just wasted 30 seconds of my life
Old May 8, 2006 | 07:49 AM
rjgto's Avatar
I didn't ask what a book says the ratio should be, i asked if anyone has MEASURED it. So did you measure your lobe lift, measure your lift at the retainer and get 1.70 exactly? - boy if you did then this factory LS1 rocker gear is better than any of the Jesel/T&D stuff i've seen.
I am running in a racing class that REQUIRES stock rockers and need to know what kind of range the rocker ratios are coming out to be.
Old May 8, 2006 | 07:51 AM
rjgto's Avatar
Originally Posted by RedLT4Mike
Not advanced tech.
A simply genius post.
