Quick question on afr heads.
Old May 9, 2006 | 07:12 PM
5.3litre's Avatar
Default Quick question on afr heads.
I ordered some afr 225 heads that are large bore heads. in the instruction sheet for the heads it says to use a minum of 4.135 bore size for the head gasket. this makes no sense to me because my motor is a 370ci and the bore is a 4.030 ... can someone explain this to me? thanks
Old May 9, 2006 | 07:15 PM
vettenuts's Avatar
It might be the combustion chamber width or the flare at the top of the sleeve. Ask Tony, sure he can answer this one.
