Broken rod bolt?
Old May 12, 2006 | 08:53 AM
you2slo's Avatar
Default Broken rod bolt?
How many have broken a rod bolt? How high were you spinning the motor? What year was the motor? How much damage was done?
I'm just trying to decide how necessary it would be to change to Katech rod bolts for a cam only car with a 228/228 cam that spins to 6500RPM.
Old May 13, 2006 | 10:55 AM
RoastEmSS's Avatar
ull be fine with the stockers with that cam
Old May 14, 2006 | 11:24 PM
SHINER's Avatar
will stock rod bolts in the 99 LS1 support a TR230 cam?
Old May 15, 2006 | 12:20 AM
RoastEmSS's Avatar
depends how high u spin the motor, i wouldnt feel comfortable revving the stock rod bolts past 6600 rpms
Old May 15, 2006 | 05:23 PM
Slacker's Avatar
I been spinning my 98 to 67-6800 for over 100 passes without an issue but it could spin a bearing tomorrow. You never know, I just swap cam's & have my car up in the air prepping to swap the k-member & new rod bolts for peace of mind.
Old May 15, 2006 | 05:26 PM
redtail2426's Avatar
i just put in a 228/230 with heads and i swapped to the katechs for peace of mind also.I will only be spinning to 64-6500.no real gain going much higher.
Old May 15, 2006 | 05:43 PM
Slacker's Avatar
I have gain a few 10ths shifting higher being that my car is an auto & this vig3200 has a poor shift extension. I've been shifting at 6750 & it drops to 4800 via EFI log (the stock tach is just slow). With good rod bolts the stock bottom end can handle alot. I plan on keep raising the shift point until my times stop improving. With a good cam/tune you won't make any more power after peak but it should flat line. And with the high shift point you will be farther in the power band on your next gear. I just like to get everything out of my set up as possible before my next mod. Sorry to carrier on
