WTF is this ticking noise???
Old May 12, 2006 | 05:35 PM
hurley711's Avatar
Default WTF is this ticking noise???
After cam swap my car developed a nice ticking noise. Thought maybe it was exhaust leak but after tightening headers real good it still persists. Hardened pushrods were installed, and spark plugs were put in 6 months ago during header install. Ticking is coming from the rear of the engine, can't tell if it's drivers or passenger side. It happens at all times while the engine is running, but intensifies loudly during acceleration. No noticeable power loss during everyday driving.
Old May 12, 2006 | 06:50 PM
jub jub's Avatar
A search of the word "ticking " produced 10 pages of excellent reading on the subject.
It's a fact that these engines like to tick. Some more than others. You might as well get use to it!
Old May 12, 2006 | 07:24 PM
hurley711's Avatar
That search also produced diff situations then the specific one I explained. I figured with solid details of my SPECIFIC situation explaining the exact mods I did would MAYBE help narrow it down. I understand what the search button is trust me I use it several times a day. This ticking is loud and by no means normal.
Old May 12, 2006 | 07:28 PM
joshp14's Avatar
Is it consistent with crankshaft speed, camshaft speed, or vehicle speed? Since the crankshaft turns twice for every one time the camshaft turns...it will help diagnose it. More than likely its a valvetrain problem...but who knows.
Old May 12, 2006 | 07:37 PM
hurley711's Avatar
The higher up I spin the RPMs the louder and faster it gets....I will pay more attention tom. when I drive it again.
Old May 12, 2006 | 07:42 PM
N01SS's Avatar
check the bolts at your collectors, look for black streaks...and if you still have your AIR check that out to, after i got my headers it didn't want to seal all the way. might need a new gasket or something
Old May 12, 2006 | 08:02 PM
hurley711's Avatar
AIR and EGR both deleted...maybe AIR not blocked off all the way in the back?
Old May 12, 2006 | 08:09 PM
Cop Car's Avatar
lifters
Old May 12, 2006 | 08:10 PM
TAWSSIX's Avatar
Check the spark plugs...make sure they are tight!
Old May 12, 2006 | 09:31 PM
hurley711's Avatar
Should I be cautious about spinning this too high until I figure out what's going on here? How cautious should I be?
Old May 12, 2006 | 09:35 PM
SHINER's Avatar
dude u never know a may be an exhaust leak i got a ticking and its an exhaust leak.
Old May 13, 2006 | 10:06 AM
hurley711's Avatar
OK guys here is the update. The ticking is coming from the passenger side of the engine. It gets louder and faster during acceleration and slows while I slow down. Also forgot to mention that after cam swap I switched to Mobil 1 full synthetic for the first time, don't know if that factors in or not.
Old May 13, 2006 | 10:15 AM
DarkblueTA's Avatar
check your spark plug wires. I had the same thing happen to the TA only to find out that one of the wires wasn't on quite all the way. If you check them and they are ok, I'd check elsewhere. Double check the rockers and make sure they're toqued down to 23ft-lbs.
Old May 13, 2006 | 12:04 PM
hurley711's Avatar
P0174 code just set, lean bank 2 the **** keeps piling on. Cam swap was biggest mistake I've ever made
Old May 13, 2006 | 12:33 PM
Doc's Avatar
Doc
The 174 code seems to suggest further evidence of a leak on the passenger side dude. Rejoice in that for a few seconds...be absolutely certain this is not up top and or outside before you start pulling heads for the lifters... The sound is all the time? Hot, cold, high rev, idle... sounds more like a exhaust leak. What kind of exhaust set up do you have? What did you have to dismantle to do the cam swap? I know this sounds like my wife asking the stupid questions when I am franticaly hunting for my keys but...
Old May 13, 2006 | 12:59 PM
hurley711's Avatar
174 code just set this afternoon. Also had a little backfire yesterday for the first time in a long while. The car ticks all the time....idle, accelerate decelerate you name it. It is really loud and obnoxious when I hit the throttle though, and the higher up I go the worse it gets. It is extremely noticeable, sounds ghetto IMO and it is driving me nuts. My idle is also dipping down occasionally to 600 RPMs when I pull the car out of gear, but it recovers right back up to 900 RPMs. As far as exhasut setup I have Pacesetter LT along with a Hooker CB. Lt were installed with new spark plugs and O2 extensions back in Sept. Cam was installed in Feb./March.
Old May 13, 2006 | 02:48 PM
Viper's Avatar
What springs with the cam? Retainers? As mentioned, check for loose rocker arms; did you use loctite on them?
Old May 13, 2006 | 03:01 PM
camaro_five0's Avatar
I've heard of LS1's having a history of piston slap...nothing dangerous to the motor but annoying.
flippin's Avatar
Its your o2's or your extentions, get the corvette o2's they have the longer wires already on them. The ticking is your spark plugs.
Old May 13, 2006 | 03:11 PM
hurley711's Avatar
Think it could be the plugs even if they were changed out during header install in Sept? Wires are still stock.......As far as cam titanium retainers and new 918 springs were installed too.
