Older XE lobes
Old May 13, 2006 | 12:20 PM
FIVE-O's Avatar
Default Older XE lobes
I see there are a few of you out there still using some of Comps older grinds.
The one I cant find any threads on is the 228/232 .539/.541.
Anyone have any experiance with this one?
Its been recommended by my tuner. He's not a big fan of big lift...and I agree to a certain extent.
Im only looking for some general impressions/thoughts.
Thanks.
Old May 13, 2006 | 12:43 PM
cenTX-LS1's Avatar
There has been talk of this cam on XE-R lobes with a 110 lsa+2 for lots of torque and a nice peak at about 6200-6300. I will be going with it on XE-R lobes because the lift is still under .600 . You would give up some midrange with the XE but I'd be willing to bet its an ok choice. I'll let one of the gurus chime in.
Old May 14, 2006 | 12:48 AM
FIVE-O's Avatar
I have thought of going XE-R, but for the minimal gain (at least for my application) + added expense of dual springs/seats etc...Im likely staying with at least XE lobes.
Ive had several recommendations, but this one seems to be calling out to me
Sometimes you just gotta go with your instincts.
Old May 14, 2006 | 10:08 AM
FIVE-O's Avatar
Anyone?
Old May 14, 2006 | 10:41 AM
PREDATOR-Z's Avatar
With today's spring tech, running such medium size durations without lifts will only diminish its output.
Look at XFI and LSK lobes (XE-R are becoming mild )
Good cam to add a set of 1.8 Crane rockers though.
Old May 14, 2006 | 10:51 AM
UltraZLS1's Avatar
it is crazy how the cam scene changes in this ls1 community.
A few years ago a 220's duration xe lobed cam was considered very aggressive.
When I bought my xe-r cam a couple months ago xe-r was considered aggressive...I guess now it is already moving down the totem pole.
Old May 14, 2006 | 11:32 AM
1999 SS's Avatar
i had a 228/232 xe-r cam in my SS for almost three years but i beleive lift was a bit higher. it has an aggressive idle and comes on like a light switch at about 3500rpm and in my car peaked at about 6800rpm.
i just recently swapped out to an f14 232/234 and feel that this is a much better more streetable cam. f14 makes more torque and comes on alittle earlier and idle is about the same.
Old May 14, 2006 | 01:29 PM
cenTX-LS1's Avatar
on a lower LSA (110+2) the cam you mentioned isnt nearly as radical
Old May 14, 2006 | 02:34 PM
FIVE-O's Avatar
Thanks guys.
The one thing im trying to avoid is the added cost of doubling up on the springs.
I was wanting a bit more durations this time as my '04 had a baby cam (TR220). It had all the torque you could ask for....too much, actually.
But I also want to stay with the 918's.
If I go too much lift, you fall in that gray area of.....918's will work...but, be smart and go duals.
My car is not a track car, so I wont be beating it silly.
Real reason Im asking is because I see similar cars with like setups: 1 with a TR224 and 1 with older XE lobes...say a 222/224. Both make very similar power. So, I ask myself, why add undue stress to the valvetrain when I can get like results from a slightly less aggressive profile.
Am I making sence? Sorry, I knew if I got too involved I would start rambling.
And for those that want to know....my car is an M6, stock except for Lt's and full 2.5" exhaust.
