help OMG metel rods on oil plug!!!!!!!!!!!!!!!!!!!!1
#61
I'm still in the same boat, as I wait for other parts. I did not catch it that 'early', and did not find any in the heads, valve springs, etc. I'm still rolling the dice on what I'm going to do.
#62
yeah just for a lil more pice of mine when i get the cam installed im gonna have them drop the pan.
raced a 4.6l gt on the way home lol he has his gf with him made him look like a tool
#68
i replaced the bad rocker be for i drove it again.
i flushed it out as best i could. i filled started drained and straind the oild about 6 times be for taking for a short drive, every thing seams just fine,
#71
This is all getting slightly out of control.Pull the rocker covers and check around with a magnet and strong torch.
Pull the pushrods and use a stick magnet and check the lifter trays.
Drive the bloody car and stop worrying.
You will have no issues.
Pulling the pan is silly talk.
#72
Originally Posted by TheBlurLS1
I've read that they can't fit through the oil pump pickup screen, so there's a little peace of mind for you.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I pull the the ole pen magenet trick, and got 5 on the first time I put it in, and 4 a few tries later. So I'm left missing one (If there are 33 per side).
#73
#75
Thanks Vortecfcar for the translation.A word or two slips past me every now and then.
Here are some Aussieisms.
Bonnet=hood
Boot=Trunk
Sump=pan
Mudguard=Fender.
At 4am my brain forgets to translate.
Ciao
Bonnet=hood
Boot=Trunk
Sump=pan
Mudguard=Fender.
Ciao
#76
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
![Stupid](https://ls1tech.com/forums/images/smilies2/stupid.gif)
#78
get yourself some thin magnets maybe even some that are extendable and have a ball joint head. that will help you fish for them in the senser hole that plugs into the oil pan. It worked well for me when i dropped washers in my oil pan. take of the intake and get a flash light to see if any are caught in there your magnet is your best friend!!!
