Help me figure this out!
Old May 13, 2006 | 03:03 PM
wws699's Avatar
Default Help me figure this out!
I've been having problems with #6 spark plug fouling. Pulled the plugs today to see what they looked like. #6 has lots of carbon and fuel build up again, the threads are oil soaked. All the other plugs look good no oil on the threads no build up of any kind. Did a compression test all pressures are between 150-155psig. Trying to figure out if I have bad rings or maybe something is wrong with the head. Is there anything else i can do to pinpoint the problem? Thanks for your time.....
Shawn
Old May 13, 2006 | 03:05 PM
indyboom's Avatar
how is it running? maybe a bad injector and a small oil leak fron the valve covers..
Old May 13, 2006 | 03:15 PM
wws699's Avatar
runs decent for being mostly stock. No oil is leaking from the valve cover..
Old May 13, 2006 | 03:51 PM
wws699's Avatar
anyone??
Old May 13, 2006 | 03:55 PM
2K2WS6TA's Avatar
Check the valve seals
Old May 13, 2006 | 04:40 PM
wws699's Avatar
bunch of one liners in here. anyone have an intelligent thought?
