removing engine from the top
Old May 13, 2006 | 03:39 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Default removing engine from the top
I got the engine down to the block. I just need to remove all the grounds and whatever is still attached.
Now. I am wanting to leave the tranny in when I do this. So all I need to do is support it with a jack correct? as I unbolt it from the engine.
Now once I have everything removed and the tranny unbolted, is it just lift and pull out? is there anything else I should know before I do this?
Old May 13, 2006 | 03:44 PM
conan's Avatar
Ya put a jack under the trans and leave the trans mount bolted to the car. After everything is un bolted you might have to take two screw drivers and pry the bell apart from the block.
Old May 13, 2006 | 04:24 PM
ricethis98's Avatar
its a lot easier if u take the tranny out with the engine, all at once. trying to re connect the two while the engine is in the bay can be very fun
Old May 14, 2006 | 01:41 PM
SVC707's Avatar
ah i see your in the same situation as me.. i too am trying to figure out whats the better approach. when i put the motor back in i will be going from the bottom though fully assembled
Old May 14, 2006 | 01:46 PM
Lithium's Avatar
Yup! thats what mine looks like. Let me know how it goes. Or better yet any tips or even a half assed write up would be greatly appreciated.
Old May 14, 2006 | 01:53 PM
Lithium's Avatar
Also is this like the ultimate time for a clutch swap? if I decide to pull both the motor and tranny?
Old May 14, 2006 | 02:03 PM
SVC707's Avatar
i see youre in CA also too bad we cant work on eachothers and make it alot easier =)
Old May 14, 2006 | 02:09 PM
Lithium's Avatar
Seriously!. I am sure there is not that much more involved in this. Its just doing it for the first time that is annoying - for me atleast.
Old May 14, 2006 | 03:42 PM
Reject's Avatar
sups lith, puttin in the 408 yes?
Old May 14, 2006 | 05:52 PM
Lithium's Avatar
nah..I wish man. I got a h/c motor with like 34k on it.
Old May 14, 2006 | 06:47 PM
Viper's Avatar
I pulled the tranny off the motor first (pics on site) only because I couldn't get the cherry picker high enough to pull both.
Old May 14, 2006 | 07:04 PM
ArcticZ28's Avatar
It's a lot easier to maneuver in and out with the tranny detached when pulling from the top. I know this from experience. It's obviously up to you and based on preference but if you're pulling from the top it's quite simple and just takes some adjusting using a load balancer. It's not THAT hard to mate the engine back up to the tranny but it is a bit tedious. This would be quite the time for a clutch swap but then again that's adding to the mix of trying a bunch of new things at once, which if something does go wrong (we're all praying nothing does) will leave a lot to question. It's up to you though, installing a clutch with the engine out is pretty much cake, just whether you wanna add it into the mix. If it were me doing it myself, I'd probably just ride out the clutch you have now and then have a reputable shop do it in the future so you can hold someone else accountable for getting the install perfect. Clutches can be a huge bitch.
Old May 16, 2006 | 05:52 PM
Lithium's Avatar
alright cool. I ll just do that then. I mean I can definitely see something going wrong with the clutch swap and the engine swap. So both at once would not be to good.
I am going to get the tranny dettached tommarow and hopefully get the engine out as well.
Old May 16, 2006 | 06:06 PM
udlose99ta's Avatar
hey Lith, the ms3 is great... (needs some better tuning) tsp ls6 heads next! good luck on the pull, i pulled a lt1 shortblock with the t56 att. thru the top no biggie
Old May 16, 2006 | 06:16 PM
Lithium's Avatar
badass man. I am glad you like it.
what kind of tune you got on it right now?
Old May 16, 2006 | 06:19 PM
udlose99ta's Avatar
pcmforless
Old May 17, 2006 | 12:39 AM
Lithium's Avatar
Alright I am going to leave the tranny in then.
Now how many bolts is it to disconnect them? I think I saw all of them...are there any hidden up top?
Old May 17, 2006 | 01:08 AM
Redneck Z's Avatar
What heads/cam come with the motor? My friend said he sold you his TSP lid. Hope this project works out better than the last one!
Old May 17, 2006 | 01:13 AM
Lithium's Avatar
Yup! he was looking to swap lids and I had what he wanted plus he felt bad for me so it worked out good.
I ll dig up the thread real quick.
https://ls1tech.com/forums/midwestern-members/474663-440-rwhp-h-c-motor-sale.html
Old May 17, 2006 | 01:27 AM
Redneck Z's Avatar
https://ls1tech.com/forums/showthread.php?t=474663
Nice! Should be a strong runner.
