AFR 225 Bolt in intake tract?
Steve
Steve
Steve
I didn´t even see teh bolt holes untill I installed the rockers. Its nothing another lb of boost wont cure
if i were u i wouldnt even worry about it... i gurantee that wont make even a 1hp diff with that bolt being in there......
oh well
oh well
yeah who knows haha.....
This situation will be present with ANY ported heads that remove the factory GM bolt boss which obviously impedes flow. It is NOT related to just an AFR product. (Which I think covers about 99% of the ported heads on the market).
The paint is a good idea for someone that doesn't have alot of experience with a grinder. I torqued my Crane Shaftmounts down, ground the bolt flush with the roof of the port, backed out the bolt and deburred the sharp edges, reinstalled back to the same torque spec for a perfect fit. I DON'T recommend this method unless you have alot of experience preferrably porting cylinder heads and the like....it's easy to slip off the bolt and screw up the shape of the port's roof which will cost you power, not help you make more.
Whats it worth??....probably not alot, but it's one of those attention to detail things I'm always preaching about that the average guy doesn't do (or even notice), and it might be worth a couple of ponies when the smoke clears....especially on some of the longer bolts with some kits that really stick down into the port (the example in this thread wasn't too bad).
Hope this helps (and gives you "****" guys something else to do...LOL)
Tony M.
PS....Don't forget that each of those eight intake bolts are now fitted to their perspective runner....mark them in the event they come out down the road. If you mix them up they will not fit perfectly flush in the wrong hole and it would be a time consuming PITA trying to figure which bolt goes where for best fit.
Tony M.
I didn't mean to single out your product, infact I think the heads look BAD ***
the bolt thing just cought me by surprise. I think it will put down lots of power, results next weekend
Tony M.
OTOH, it would be a nice touch if heads came with a set of one-off matching rocker bolts.
Just kidding!
Also I didn't use any kind of thread sealer on the bolts because I didn't know they were going to protrude. Now I guess I ahve to redo it
