Preload issue, need educated opinion
Old May 14, 2006 | 09:35 AM
zkeller's Avatar
Default Preload issue, need educated opinion
When I orignally put my motor together, I did not check the preload, so yesterday I pulled the valve cover off and used a dial-indicator to check it.
I am coming up with .050. I am using 7.400" CompCams PR. I know the range is .050 to .100 and if I go to the next size PR is 7.450". That would put me at .100 and probably quiet the valvetrain down.
I would rather split the difference and go with a PR that is in the 4.430" range, but that does not seam to be an option.
My lifters are CompCams OE ProMagnum, Rockers are Jessel 1.7 and the cam is a CompCams 232/234 .595/.598 LSA 112.
Should I leave it alone, or get the longer PR?
Old May 14, 2006 | 12:44 PM
vettenuts's Avatar
You could try it and see how noisy it is. Or, you could use the 7.425" Comp pushrods.
From Thunder Racing web site:
63-7796-16 Comp Cams Hi-Tech One-Piece Chromemoly pushrods, 7.425" (.025" Long LS1,-2,-6, Gen III)
Old May 14, 2006 | 01:13 PM
Ping King's Avatar
you are checking this when the motor is hot..correct?
i usually run preload a little on the softer side.
if this is when the motor is hot, then i think you should still be ok.
Old May 14, 2006 | 06:32 PM
SSchester's Avatar
I have the same cam in mine and I keep getting this annoying ticking/knocking sound. I currently have 7.4 pushrods do I need the 7.425's to fix this?
2000 Camao SS
Old May 14, 2006 | 07:58 PM
zkeller's Avatar
I checked it cold, lifter pressure bled off.
Old May 15, 2006 | 08:20 PM
zkeller's Avatar
I called Comp Cams and they said to run between .040 and .060 on that cam/lifter package.
He also stated that cam has the tendancy to make a little more valvetrain noise.
