wiped cam bearing?
Old May 14, 2006 | 05:48 PM
Big Budda's Avatar
Default wiped cam bearing?
I took the old cam spun it no noise at all.
When I installed the new cam and spun it it soungs like its grinding .Is this normal?
I'm hoping its just cause theres no oil in there yet
Old May 14, 2006 | 05:52 PM
BlackWidow's Avatar
Not normal
Old May 14, 2006 | 05:54 PM
Big Budda's Avatar
any sugestions?
Old May 14, 2006 | 05:57 PM
BBADWS6's Avatar
If you are going to try and compare the sounds of the bearings you need to simulate the exact situation with both cams.
If the cam you pulled out was oiled, oil the second cam. I sure as hell hope you installed it with some assembly lube, if not you are going to have some problems.
You may want to check and see if there is some dirt or debris on the cam.
If the cam bearings are worn bad you will be able to see the color of the bearing itself (not the coating), its pretty obvious.
Old May 14, 2006 | 06:00 PM
Big Budda's Avatar
I cleaned it before i installed it.I also used assembly lube and oil
Old May 14, 2006 | 10:50 PM
Demon SS's Avatar
did you twist the cam while installing or did you go straight in? if you were twisting it you may have scored/gouged the bearing. i would pull the cam back out and use a good LED light to look into the bearings to see if that may be the case. But it isnt normal for there to be a grinding noise. Hell if you use a good assembly lube somtimes the weight of the timing gear pin is enough to make the cam rotate till the dowel hits bottom.
Old May 15, 2006 | 07:24 PM
eallanboggs's Avatar
Grinding noise? No way! If you had to ask the question it's time to get somone to help you with this install because your question answers itself.
Old May 15, 2006 | 07:40 PM
Big Budda's Avatar
This is my first install.You can never be too carefull right.
The noise was tha cam rubbing either on the cam sensor or the back of the block.I didnt have the cam gear on and it was pushed back too far
Installed the cam gear and no noise smooth as a whislte
