sewing machine sound?
Old May 14, 2006 | 07:47 PM
Rays C5's Avatar
Default sewing machine sound?
I've had this sound since cam change(c.c.212/218) using stock lifters,pushrods and rockers. From my understanding a lot of guys are going to a slightly longer pushrod, or changing to the yella terra(sp?) rockers to correct. My question is did anyone notice a performance increase from correcting this issue?Assuming valve is not fully opening or seating with correct spring pressure. Which method did they use and why? BTW preload I believe is correct.
Old May 14, 2006 | 10:29 PM
markp03's Avatar
if it is really loud i would check the exhuast gaskets in your headers or manifolds...
