Main caps??
Old May 15, 2006 | 06:26 PM
94redz28's Avatar
Default Main caps??
I am about to install my new crank and i cant find the torque specs and sequence. I am using gm main bolts if it makes a difference. Also is there any trick to installing the main bearings?
Old May 15, 2006 | 07:49 PM
94redz28's Avatar
Anyone
Old May 16, 2006 | 04:59 PM
94redz28's Avatar
Please help
Old May 16, 2006 | 05:01 PM
Jason99T/A's Avatar
I can shift faster than you.
Inner bolts: 15lb-ft + 80 degrees
Outter bolts: 15lb-ft + 53 degrees
Side bolts: 18lb-ft
Jason
Old May 16, 2006 | 05:15 PM
94redz28's Avatar
I thought it would be alot more than that. Why so low?
Old May 16, 2006 | 06:24 PM
2 SSlow's Avatar
the degrees is where the torque really is. Streching the bolts.
