LS6 Cam question
Old May 16, 2006 | 06:59 PM
LS144's Avatar
Default LS6 Cam question
If you do a ls6 cam swap can you use your stock pushrods and rockers even springs????
Old May 16, 2006 | 07:34 PM
HOSS's Avatar
You need to go to the 7.425 prs, and move up to the LS6 springs. Stock pr's will work, but if you want the full power of the cam, you need the longer pr's
Old May 16, 2006 | 08:03 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not to mention that the stock pushrods are pieces of ****. I would get some hardened pr's and like HOSS said 7.425-7.450 might quiet down the valve train as well.
