** Need help asap** Harmonic balancer bolt install
I went to install an ARP balancer bolt on my ('99 vette) LS1. It threaded about 6 threads in and stopped. I too bent tools trying to get it to turn further. It took 4 of us to get it back out (fortunately, my engine was on a stand) but when it came out the threads on the ARP bolt were toast. (We thought we'd just break the bolt head off and have to have a machine shop fix the crank)
The bolt went in straight, too so I have no idea why this happened. The bolt length was identical to the factory GM bolt, too.
I ordered a metric tap and chased my threads out which, fortunately, the threads on the crank were fine. Just the ARP bolt went bad.
Then I installed a new bolt with no hassle whatsoever. Now its fine. Still don't know why it happened...
My leasson learned was to chase the threads. It's possible GM used some sealant or something on the threads (sometimes GM threads come with a blue colored threadloc, too) and this gummed up??
I hope this is helpful.
it to the 250ftlb. Now the car is running and no problems. Thanks guys for all your input. If not I don't know how bad off I would be.
torqued the old bolt down to 250 - got a phone call, forgot about it, packed up my stuff, threw the belt on and took it for a spin. About 20 miles later the car spit the belt - THANK GOD - I opened the hood, no belt, no bolt and the ASP was about 1/4" from falling off Opened up my tool box and saw my new bolt...
What I do, is use an old bolt and cut groves in it on opposite sides and make my own chaser to clean the threads with then reinstall the new bolt to tighten down.
