Need help bad with head stud question???
Old May 17, 2006 | 06:43 PM
SPRAYED 01's Avatar
Default Need help bad with head stud question???
I think i have an easy question. All mods in sig, except im installing a fast 90/90 and some tsp ls6 heads. my question is in order to use arp head studs to i need to pull the motor? i want to leave it in the car. also do i install the studs first or the heads? thanks
Old May 17, 2006 | 06:53 PM
sickss228's Avatar
No need to pull the motor, and yes install the studs first.
Old May 17, 2006 | 07:56 PM
Bad30th's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/488563-torque-specs-arp-head-studs.html
Rob (Bad30th)
