torque specs for ARP head studs?
Old Apr 13, 2006 | 11:27 PM
destroyerSS's Avatar
Default torque specs for ARP head studs?
Anyone know the specs for the studs into the block then for the nuts onto the heads?
Iron block
AFR225's
.040 Cometics
Old Apr 14, 2006 | 04:22 AM
curtbriggs's Avatar
Default ARP Studs
Sorry, I missed that you have an Iron Block, check with ARP.
First, make sure there's no coolant in the block bolt holes or when you install the studs or bolts, you'll hydraulic the hole bottom out and ruin the block.
Use anti seize on the studs and nuts.
The studs aren't torqued just hand tightned with an allen wrench.
The 10 ea. 15mm stud nuts are torqued in 4 stages, 22, 30, 50 and 70 ft. lbs.
The 5 small nuts are 22 ft. lbs.
These are from my notes, there is torque specs on the installation sheet that ARP sends with the kit. Check that all the nuts screw onto the studs before you start, I had one bad nut. If you get stuck, you can use a lug nut on the stud next to the header flange, until you get the replacement nut from ARP.
Old Apr 14, 2006 | 05:32 AM
vettenuts's Avatar
Not sure on the iron block, talk to ARP. Just to add one thing, the washers go on flat side down.
Old Apr 14, 2006 | 07:51 AM
GENIII's Avatar
curtbriggs... I think you meant to say use ARP molly lube on the threads not anti seize.
Old Apr 14, 2006 | 12:37 PM
DEVIATE's Avatar
ttt I would like this info as well. Is the above info for the aluminum or the cas iron. Sorry it could be take either way. Just want to make sure
Old Apr 14, 2006 | 03:44 PM
vettenuts's Avatar
I spoke to ARP on this several times. For aluminum, 70 lb-ft on the big ones, 23 lb-ft on the small ones. I just don't know about the iron block so best to speak directly with ARP. These numbers are using their assembly lube.
Old Apr 14, 2006 | 04:40 PM
smask04C5's Avatar
Same torque values for either, just make sure you lube up each stud with moly, bottom the stud into the block by hand with the correct size alan wrench, then back it out 1/2 turn. Do not torque stud into block!
Old Apr 14, 2006 | 04:51 PM
DEVIATE's Avatar
Thanks man I apprecate it.
Old Apr 14, 2006 | 05:14 PM
Black Z/28's Avatar
Here's my ARP installation instruction sheet:
Old Apr 14, 2006 | 05:18 PM
Bad30th's Avatar
We don't need to use the thread sealer on LS1/LS6 blocks, correct ?
I'm about to order some moly lube from ARP and am wondering if I need the thread sealer too. Our studs don't go through any water jackets, do they ?
Rob (Bad30th)
Old Apr 14, 2006 | 05:21 PM
smask04C5's Avatar
No, sealer is not necessary on Gen III blocks, at least for the studs
Old Apr 14, 2006 | 05:39 PM
Lithium's Avatar
SSU's Drunk Typing Whore
www.blackcamaro.com
Old May 22, 2006 | 12:02 AM
ArcticZ28's Avatar
Bringing this one back.... thanks for posting the instructions Black Z/28. I lost my directions for my 12pt studs a while ago but I thought I remembered something about torquing them in increments such as 20, 30, 50, 70? Anyone else recall this?
Old May 22, 2006 | 03:47 AM
Black Z/28's Avatar
Definitely 3 passes. Seems to me I did 30, 50, Final. Maybe someone else can chime in.
Old May 22, 2006 | 05:34 AM
vettenuts's Avatar
Yes, as long as the nut is moving when you hit the torque value. I don't like the Blackcamaro method, spoke to ARP about it and they stated the multi-stretch was for rod studs.
