harmonic balancer removal
Old May 19, 2006 | 02:36 PM
SiRgReg23's Avatar
Temple, TX Resident
Default harmonic balancer removal
the balancer bolt turns everytime i turn the bolt on the pulley puller ... am i doing something wrong ?
Old May 19, 2006 | 03:06 PM
vettenuts's Avatar
If you have the balancer bolt loose, the puller on and the puller bolt is turning the balancer bolt, put a second open end wrench on the balancer bolt to hold it. The balancer bolt should only be a couple of turns when you start, back it out as the balancer comes off.
