Hot Cam Question
Old May 19, 2006 | 11:52 PM
CChatter9's Avatar
Default Hot Cam Question
I was just wondering the best rockers and pushrods to go with the GM Hot Cam for the LS1?
Old May 19, 2006 | 11:56 PM
Redneck Z's Avatar
Stock rockers and any hardened pushrod. A hardened pushrod is a hardened pushrod. Alot of the companies buy them from the same place and put their name on them.
Old May 19, 2006 | 11:57 PM
staringback05's Avatar
u might want to take this post to internal ull get more answers in there
Old May 20, 2006 | 12:09 AM
TheBlurLS1's Avatar
That's what she said...
Allow me....
BTW - Don't run hardened pushrods with stock valvesprings, it could spell disaster.
Old May 20, 2006 | 02:35 PM
Bigdeezs's Avatar
Why's that?
Old May 20, 2006 | 03:28 PM
Redneck Z's Avatar
Originally Posted by Bigdeezs
Why's that?
You shouldn't be running stock LS1 valve springs anyways. For that cam, you can run LS6 springs and hardened pushrods.
Old May 20, 2006 | 05:08 PM
TheBlurLS1's Avatar
Why's that?
Because if the valves ever hit the pistions (mis-shift/over-rev), it will bend them instead of the hardened pushrods.
I'd rather change pushrods than valves.
Old May 20, 2006 | 05:09 PM
TheBlurLS1's Avatar
I think a set of comp 918 springs are the hot ticket for this guy, they are cheap and much nicer than the LS6 springs, which might still let a valve get bent on a mis-shift/overrev.
Old May 20, 2006 | 05:50 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
918's are the way to go.
Old May 20, 2006 | 08:40 PM
Bigdeezs's Avatar
Silly me I was thinking hardened pushrods with stock cam and springs not with the hotcam
Old May 20, 2006 | 09:45 PM
blkbird's Avatar
Keep the stock rockers. Any 7.4 hardened pushrod will work.
Old May 21, 2006 | 07:05 PM
CChatter9's Avatar
Thanks a lot guys
