Motor need a bigger cam, what to do?
My mods are listed in the signature. Obviously the cam I have is quite a bit too small to really utilize these heads. Is there any kind of range someone could suggest for them? I know it's a pretty vague question but any guidance would be appreciated. Thanks!
EDIT: Streetability is not a concern.
1 Post
My car was professionally done by LG Motorsports, and I totally endorse everything Lou sells. If you want a big cam you can go with the G5X3 or the bigger G5X4 also a custom grind could be arranged. Give Bobby or Anthony a call 1-972-429-1963 to find out if you need to flycut your pistons. The X3 is good for 50-70 rwhp over stock in C5 Corvettes and the X4 is even more. X3 is more streetable, X4 is rougher. Tell them that Doug sent ya. Hope this helps.
