Another 5.3 question.
Old May 21, 2006 | 10:42 AM
LS144's Avatar
Default Another 5.3 question.
Okay I have got the 5.3 heads coming but comes with no valve covers can I sue mine fro mthe stock heads?? And also what else will I need to do to make it work? Id say a coil relocation kit to right?
Old May 21, 2006 | 11:15 PM
LS144's Avatar
Up up and away
Old May 21, 2006 | 11:38 PM
Xtnct00WS6's Avatar
I'm almost postive the stock valve covers will work fine if it's 99+ What year is ur car?
Old May 22, 2006 | 05:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you have perimeter bolt heads which came on the 98" cars you will re-use your stock valve covers. If you have 98 heads and did not specify when ordering you will need new center bolt valve covers.
