Which cam is better?????
Old May 22, 2006 | 10:37 PM
SHINER's Avatar
Question Which cam is better?????
Im trying to decipher which reverse split is better for my setup:
i have headers in a lid, and i understand LS1 heads flow better on the exhaust side than the intake, and i plan on keeping my LS1 heads(stock). So with this setup im going w/ a reverse split. Any opinions are very much appreciated!
Thanks
Travis
Patriot Performance Cam 110 LSA, 232/230 Duration, 580/580 Lift
Patriot Performance GM LS1/LS6 CAM (Billet) 232/230, 110 LSA, 580/580 Lift
vs.
99-TR230/224-111 Thunder Racing Custom "Reverse Split" Camshaft - 230/224 .575/.563 111 LSA 2200-6800 RPM Power
Old May 22, 2006 | 10:51 PM
Gearhead1's Avatar
Here are the flow numbers for a stock LS1 head
https://ls1tech.com/forums/attachmen...chmentid=51779
I wouldn't say that the exhaust flowed better than the intake by looking at these flow numbers.
Old May 22, 2006 | 10:56 PM
SHINER's Avatar
well which lobes are more aggressive of the two cams I understand patriots lobes have the higher duration but im talking about cam lobe profiles(XER, LGK, etc.)
Old May 22, 2006 | 11:25 PM
SHINER's Avatar
ttttt
Old May 23, 2006 | 07:42 AM
PREDATOR-Z's Avatar
Good 230 durations cams are TR230 and MTI X1
Both proven to make good power.
If you want something tamer, but still street agressive then a custom
224/220, 581/.6xx 113+0 LSA
Old May 24, 2006 | 12:21 AM
ZoFastSS's Avatar
Nice cam with some good power 221/221 558/558 114L.S.A.
