Forged?? what all goes into it
Old May 23, 2006 | 08:39 AM
FSUNole17's Avatar
Default Forged?? what all goes into it
I have a noob question about going forged internals. I am going to have a D-1SC eventually and hear that the only way to crank the boost up is to go forged. What all goes into the process of forging (is that even a word?) thanks
Old May 23, 2006 | 09:04 AM
radz's Avatar
Crank, connecting rods, pistons, I belive thats all. Pricey, but you get what you pay for. Forging is heat treated metal, it prevents cracks and breaks under high stress
Old May 23, 2006 | 09:19 AM
conan's Avatar
If you are going to get a forged SB check with some sponsors I got mine from texas speed for 3100. Also if you dont want a bigger cubic in moter get the SB with a stock crank and forged rods and pistons.
Old May 23, 2006 | 11:13 AM
MightyBobo's Avatar
Yeah, seems everyone says, stick with the stock crank - but send it out to be reballenced. Otherwise, forged rods and pistons.
Old May 23, 2006 | 11:26 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Stock crank will rock til 1200rwhp easy.
Old May 23, 2006 | 11:48 PM
FSUNole17's Avatar
thanks guys! that gives me some idea of where i know to spend
Old May 24, 2006 | 10:15 AM
moeZ28's Avatar
Make sure you get ARP rod bolts, if not all bolts to replace the factory stuff.
Old May 24, 2006 | 10:20 AM
69firebird's Avatar
If your going to be building for a blower, get lower comp pistions, forged rods, upgraded rod bolts, main studs, keep the stock crank, no blower kits out will challenge the stock crank
youd be set, with a good pair of heads to about 900hp with that setup
Old May 24, 2006 | 11:17 AM
deputydog's Avatar
Whats the fastest someone has gone with a stock crank? Not refering to 10 & 11 second cars, thats the common place. Any 9's or 8's?
Old May 24, 2006 | 11:39 AM
Fireball's Avatar
I know harlan pushed a stock crank into the 8s
