Modified & Simplified VE Calculator! - I need some input!
https://ls1tech.com/forums/generation-iii-internal-engine/511350-xfi-lobes-ls1.html
But if those number are based on GENI core, they will grow when cut on a 55MM core.
XTREME ENERGY™ XFI™ HYDRAULIC ROLLERS
Lobe# @.006 @.050 @.200 w/ 1.7
Intake Lobes
3010 252 202 128 .585
3011 256 206 132 .590
3012 260 210 136 .595
3013 264 214 139 .600
3014 268 218 143 .605
3015 274 224 149 .609
3016 280 230 154 .612
3017 286 236 159 .615
3018 292 242 165 .621
Exhaust Lobes
3033 264 212 135 .580
3034 270 218 141 .590
3035 276 224 147 .600
3036 282 230 152 .604
3037 288 236 158 .607
3038 294 242 163 .612
3039 300 248 169 .615
You may order a
XE-R 224/228 .581/.588 110lsa +1 cam
…but when you have it CamDoctored the true values maybe something like...
XE-R 224.6/227.4 .582/.590 110.4lsa + .8 cam
This is just an example....
https://ls1tech.com/forums/showthread.php?t=511350
Intake Lobes
Exhaust Lobes
Gotta go eat...
Almost forgot the link: http://www.alantripp.com/VE Calculat...igy Lookup.xls
However, if you enter a cam that doesn't correspond to any of the ones listed in the Lobe Source tab, how does it determine the durations @ .050 & .200?
For example I entered this cam 220/224 .557/.575 112 +0. I have no idea what type of lobes they are. Is the DCR that the calculator spits out correct? or does this only work for XE, XE-R, LSK & XFI lobes?
Also, right now, I have it set to just find the closest match to what you entered. For instance, if you enter a lift of .613 and and the specs from Comp are really .614, it will give those values.
im gonna download this spreadsheet, it sounds awesome.
While technically the terminology may be -.008, I think the spreadsheet requires the positive (unless I'm missing something else).
You will have Less compression with a positive number (in hole) and more with a negative number (out of hole).
Dan
