Oil pump swap
If you're changing the cam now, there is a good chance you'll change it again down the road when the car has more miles on it. Probably a good idea to change it then.
I changed mine when I did the H/C swap simply because mine had quite a few miles on it. 106k to be exact. Put a new LS6 pump in it and replaced the o-ring too.
Now makes ~60 psi on cold start up...and hovers around 40 at idle.
I'd think it over and figure out what you're comfortable with.
