Buying a Torquer 2, what else do I need?
Old May 25, 2006 | 12:52 PM
CamdLs1's Avatar
Default Buying a Torquer 2, what else do I need?
I was torn between the f13 and the torquer 2 but I've finally decided on the T2. I was also gonna get a new ls6 pump. Do I really need a ported one? Who has the cheapest? I also need hardened pushrods, 7.4 length good? Should I get an LS2 timing chain or a double roller from slp? I think I am gonna go with patriot gold dual springs. I am also gonna get a new gasket kit. Anything else? Any info on what to get or where this stuff is cheapest would really help me out, I'm kinda on a budget. Please help, this is my first cam install! Thanks
Old May 25, 2006 | 12:55 PM
shanev8's Avatar
intake manifold, ported throttle body, hp tuners, retainers, under drive pullie,
i go to thunder racing for all my crap..
there a sponser to the right ~~~~~>
Old May 25, 2006 | 12:57 PM
PREDATOR-Z's Avatar
Get7.425 p-rods, PRC dual springs, LS2 chain.
Gotta have to tune so budget for that too, otherwise just get the parts one by one and don't install untill you can tune.
If you have stock heads, get the 112
Old May 25, 2006 | 01:19 PM
RoastEmSS's Avatar
get everything from Texas Speed, i just ordered a lot from them including the T2 with Dual springs, hardened pushrods, bolt & gasket kit, powerbond pulley w/ the belts, LS2 Timing chain, and ported LS6 pump. Get the ported one. Order by phone, thye r great guys and will help u out with whatever questions u have.
Old May 25, 2006 | 02:04 PM
TL00CamaroSS's Avatar
Thats the extact same stuff i just ordered, minus the pulley and belts.
Old May 25, 2006 | 02:07 PM
slow trap's Avatar
be prepared to lose quite a bit of low end torque with that big of a stick on stock bottom end.are you set on a t2 over something like a 224/228 on a 112 +2 or similar ?
Old May 25, 2006 | 02:14 PM
co.6z28's Avatar
what you lose on the low end is nothing. if you wanna go fast you wont see those rpm at all. i had it with 3.42 gears and now with 4.30's. gears will help with low end lag
and what does the stock bottom end have to do with the loss of torque , i thought it was the rear end gearing
Old May 25, 2006 | 02:21 PM
CamdLs1's Avatar
Wow thanks for all the quick responses guys! Well I have 3.73s which should help with the low end torque issue plus I get loads of torque on spray , and this is no longer my daily driver, although it spends most of its time on the street. I just got a really good deal on an SLP double roller timing chain and oil pump.
I have a ported stock throttle body and an LS6 intake.
I was told that I could use 7.4s because i don't want too much lifter preload even though there will be less valvetrain noise with the 7.425s.
I am getting it tuned. My tuner has a special if you come back within a year a retune is only $200, rather than $500. Thats why I need to hurry cause its a year in July. The cam I have now is in the sig. The lift is in the .530s. Just wanted something bigger and I've heard good things about the Torquer 2.
Old May 25, 2006 | 02:26 PM
CamdLs1's Avatar
I also heard that the Patriot gold duals were a better route than the PRCs due to the after market locks rather than stock.
Predator-Z you have a Torquer 2 right? Hows the drivability? What did you put down on the dyno? Track times? Are you happy with it?
I am shooting for 380rwhp.
Old May 25, 2006 | 02:27 PM
CamdLs1's Avatar
I thought a 113 would be a little more streetable than a 112? But I am an M6 and didn't want to go with a 114.
Old May 25, 2006 | 02:39 PM
co.6z28's Avatar
i got it also on a 112. dyno number in sig with full bolt ons and slipping ls6 clutch.
track time was a 12.12@118 spining
i dd mine and its great
prc springs with mine also
Old May 25, 2006 | 02:41 PM
CamdLs1's Avatar
Do you have the stock length pushrods?
Old May 25, 2006 | 03:46 PM
co.6z28's Avatar
yeah if i remember right
Old May 25, 2006 | 08:52 PM
slow trap's Avatar
i was meaning with stock bottom end as having thick *** gm mls head gaskets so the dcr will be very low.i myself have switched over to the t2 on a 112 but my dcr will still be 8.7 with my combo so i will still have good torque and hopefully pick up 10 rw or more,maybe.with 3.73 cogs that should be a decent combo and 380 + should be no sweat.
Old May 26, 2006 | 12:03 AM
TopFlite's Avatar
XER lobes make me want a T2.
Old May 26, 2006 | 06:58 AM
PREDATOR-Z's Avatar
Yeah, but I had mine with 64cc heads and bigger valves (ported), so it pepped the cam up a bit. It is a nice cam, and I'm sticking it in the 6.0 i'm building, but this time, it will be optimized, 11.7 SCR and 8.7 DCR. I want max ouput out of it.
The reason I say get the 112 for stoch heads/compression is that it will raise the DCR a bit and put out more trq. 113+0 is a high spinner, and i mean high, you can go all the way to 7200 with it.
As for driveability, I was surprised how well it behaved (I'm A4) and besides a little idle hunting at times, it was fine.
Good tuning helps a lot.
Old May 26, 2006 | 12:18 PM
CamdLs1's Avatar
The problem with my tune, well, cam is that it drops idle erratically, completely dieing occassionally when the ac is on, and its very easy to disrupt it at idle. Also load from steering slowly, like into a parking lot, will make it die. Its on a 112 so I thought a 113 would be a little more streetable without sacraficing too much down low. I will only spin this cam to 6600.
Old May 26, 2006 | 12:23 PM
CamdLs1's Avatar
oh and I planned on getting heads eventually.
