highest flowing intake???
Old May 27, 2006 | 12:17 AM
98vortecbw's Avatar
Default highest flowing intake???
what is the highest flowing intake for a 408ci ls1?
Old May 27, 2006 | 01:06 AM
Kraest's Avatar
I'd use a FAST 90/90 setup.
Old May 27, 2006 | 01:15 AM
Lithium's Avatar
SSU's Drunk Typing Whore
sheet metal
Old May 27, 2006 | 01:21 AM
98vortecbw's Avatar
where do you find the sheet metal ones?
Old May 27, 2006 | 01:35 AM
beardWS6's Avatar
My fast doesn`t keep up with the ET heads I have on my 408!
Old May 27, 2006 | 01:39 AM
MountainMotor's Avatar
Originally Posted by Lithium
sheet metal
Agreed
Old May 27, 2006 | 08:09 AM
Zymosis's Avatar
They are custom made for your set up at performance shops.
Old May 27, 2006 | 09:23 AM
allngn_c5's Avatar
Sheet metal intakes must be expensive. Afraid to ask how much.
Old May 27, 2006 | 09:38 AM
Kraest's Avatar
If you want to go all-out, there's always the $3000-4000 Harrop intake
For most people, the FAST 90/90 works just fine, or a custom sheetmetal intake if you have the extra $1000 for an extra 10-15 rwhp.
Mike
Old May 27, 2006 | 12:18 PM
Benjamin Russick's Avatar
I'd wager that a good carb-style intake with a 90degree elbow would flow some big numbers for less cost than a sheet-metal intake...
Old May 27, 2006 | 12:34 PM
Studytime's Avatar
...and for less cost than a 90/90 Fast setup.
Ben T.
PREDATOR-Z's Avatar
Wilson intake
Old May 27, 2006 | 12:58 PM
I also think that you could port and polish AND get a nice SD tune on the carb-intake/elbow for less than a sheet metal intake, but you'll need a cowl hood, so that may be a limiting factor.
Old May 27, 2006 | 03:52 PM
xfactor_pitbulls's Avatar
Agreed, that is a good route to go. If you really want to get the most out of your intake, let someone experienced do it right. By that I mean cutting it in half (the right way) porting and rewelding. A bit costly ~$1K on top of the intake, but you will have a bad mother when you are done.
Brandon
Old May 27, 2006 | 04:36 PM
chevynation's Avatar
ls7 intake is cheap and outflows fast 90. gotta have $3k ET ls7 heads though.
Old May 27, 2006 | 07:10 PM
Full-Force's Avatar
Victor Jr. EFI intake all the way. Less than 400 bucks with fuel rails.
