is this cam anygood
Alright i am getting ready to buy a cam for my T/A. is this cam listed below any good.
Brand: Edelbrock
Product Line: Edelbrock Performer RPM Cam and Lifter Kits
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-5,500 RPM
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 218 int./218 exh.
Advertised Intake Duration: 286
Advertised Exhaust Duration: 286
Advertised Duration: 286 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.525 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Brand: Edelbrock
Originally Posted by orangeapeel
I would consider the TR220 or TR224 also.
Also check and read the cam sticky at the top of this forum. It will help you determine stuff you probably have not thought of otherwise.
I have the Comp 222/224 @112lsa - it's good, very good!
It gained me 40-50 rwhp right thru the rev range.
Otherwise, try the Comp 212/218 @ 115lsa .558/.563 - XR265HR, it makes good numbers also and on 115lsa would be smooth to drive.
Cheers,
Macca
Cheers,
Macca
