Damage to engine (pics)
Old May 29, 2006 | 09:34 AM
PREDATOR-Z's Avatar
Yeah, definite PTV issues.
You cannot take anyones word for it. Measuring PTV is the only way to find out. Ferrea valves loose about .020 PTV vs other valves of same size (thicker base).
Time for rebuild with forged internals and valve reliefs.
Old May 29, 2006 | 02:50 PM
Slowhawk's Avatar
LS1Tech Sponsor
Looks like a PTV problem. Look at the cylinder next to it---> Looks like the valve hit there too.
Old May 29, 2006 | 04:05 PM
hifi dream's Avatar
Yup, live and learn I guess
Here's where I left it for today (time to relax and grill out).
Motor is ready to come out. All I have left to do is drop the trans.
Old May 29, 2006 | 04:20 PM
redtail2426's Avatar
thats a shiny front cover
Old May 29, 2006 | 06:44 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
So do all of the other pistons have the same eyebrows on them? I hate to see stuff that like this happenning. I hope things get worked out for you.
Old May 29, 2006 | 07:01 PM
ShevrolayZ28's Avatar
You're taking this well. I'd be too depressed to post.
I guess even if you have P/V clearance, all bets are off if the lifter doesn't follow the cam lobe. Sucks!
Old May 29, 2006 | 09:40 PM
hifi dream's Avatar
Cylinder wall is cracked
Looks like I'd better start looking for a new block.
Frickin going from bad to worse.....
BTW, yes, all the pistons have "eyebrows". After talking it over we're thinking the timing chain broke. (haven'y got the timing cover off yet though since we broke the balancer puller). Just gets better by the minute
Old May 29, 2006 | 11:01 PM
LSXRX7's Avatar
same problem with my ls6, all from ptv clearance looks like you took pictures of my motor cracked the block in two places around water jacket.. i feel your pain.....
Old May 30, 2006 | 06:33 AM
hifi dream's Avatar
Now I just need to find the money to rebuild it
Old May 30, 2006 | 07:59 AM
jeffstar's Avatar
Well that was rather horrofic! I'd take that over a spun bearing.....er no I wouldn't, man that sucks.
Old May 30, 2006 | 08:29 AM
GuitsBoy's Avatar
Sorry to read about this... What was the total thickness of the head? Maybe it was milled more than .008? Also, were the 2.02 valves installed on a stock seat? This could put them lower to begin with.
Old May 30, 2006 | 08:35 AM
  #32
keliente's Avatar
That sucks.
About the lifter photo - they look the same to me. How can you tell the left one is bad? I don't doubt you, just wanted to know how you can tell.
Old May 30, 2006 | 11:50 AM
  #33
2000silvergtp's Avatar
That is some sick looking stuff! Sorry about your misfortune.
Best of luck in the rebuilding process.
Old May 30, 2006 | 12:02 PM
  #34
white2001s10's Avatar
Looks to me like one plunger is up against the clip and the other is not.
If it is collapsed, then if happened before or after the P/V contact is just speculation. One collapsed lifter will not cause P/V contact on all the cylinders though, so it's pretty much irrellevent.
Old May 30, 2006 | 03:11 PM
  #35
UNDER PRESSURE MOD
The only reason I ask is that the last time I pulled the cylinder head while replace a broken rocker arm stud that occurred during a broken spring change, I noticed I had very small eyebrows on my pistons. I was more under the impression that it was due to the weak valve springs I had on the car with the TR224 cam and was a result of valve float.
Who knows, I have 918s on the car now, and I don't get any KR which I would expect to see if I were kissing the pistons each revolution.
Best of luck to you.
Old Jun 2, 2006 | 06:22 PM
  #36
TheDogofWar's Avatar
I called Texas-Speed and they said there's no way that's the problem (I was running the hardened 7.400" from them). We deceided that it was the stock lifters.
I really have to ask who the above mentioned "we" is. Because I would really like an explanation to how a collapsed lifter will cause PV contact.
I'm sorry for your trouble, especially since I'm in the middle of a cam swap. Bore it, Stroke it, trash it for a new 427
Old Jun 2, 2006 | 11:16 PM
  #37
Doomsday's Avatar
Originally Posted by brokez
Damn that sucks.Been there done that don't worry you can build it bigger and better.Best of luck
And he is going to be paying for it too.....just like me with a hole in my block....
Ahhh, the story of piston meets valve...once upon a time
Good luck
Old Jun 3, 2006 | 06:39 AM
  #38
Viper's Avatar
Sucks, sorry to hear. I had a valvespring broke in 04' and caused the same, pics on my site. New forged LS6 block from Lingenfelter was only $2100 ( forged pistons, stock rods and ARP rod bolts ). I couldn't rebuild it for that price.
Old Jun 3, 2006 | 07:28 AM
  #39
allngn_c5's Avatar
sorry to hear about the mess. get her back together soon so you can enjoy the summer.
Old Jun 3, 2006 | 08:26 AM
  #40
cantdrv65's Avatar
Post
BTW, I put the stock lifters back in (they had about 60k on them).
The "tick" that it had was there from initial start-up. At first people thought it may be the wrong PR length.
Looking back on it now I wish I would've just got the new lifters when I ordered everything else
The lifters were NOT the problem. The tick you heard was the valve/valve(s)
contacting the pistons. One finally gave out. You had zero clearance with this setup. Remember, EVERY setup is different and you MUST check P/V clearance when it is going to be tight.... I nailed 10 valves on my setup due to a broken timing chain, and I suspect that was also due to P/V contact from weak valvesprings and floated valves....Im still running the SAME stock lifters, but I did have to buy some new heads. It looks like you did collapse a lifter from the impact though....
