A slight problem - valve spring swap
Old May 29, 2006 | 01:49 AM
sh33p4u's Avatar
Default A slight problem - valve spring swap
Yeah I was installing valve springs, and I dropped a lock somewhere in the valve cover area. I think it went in one of the head bolts holes right behind the valve springs, you know the really deep ones. I stuck a screw driver in there and it goes forever!! haha. Well I just wanna ask if anyone knows where this hole goes? Does it go to the oil pan or what? Thanks in advance!!
Old May 29, 2006 | 02:11 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is probably lodged in an oil passage in the block now.
Old May 29, 2006 | 06:50 AM
vettenuts's Avatar
Those holes go to the lifters. Look down the pushrod holes with a strong light.
Old May 29, 2006 | 10:35 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
pull the pushrod and try fishing it with a thin pen magnet.
Old May 29, 2006 | 12:18 PM
sh33p4u's Avatar
I'll give that a try, any more help out there? I really appreciate it, thanks.
Old May 29, 2006 | 01:13 PM
davered00ss's Avatar
Moderator
Small pen magnet, or pull the heads.
Old May 29, 2006 | 01:44 PM
sh33p4u's Avatar
I must be lucky, the pen magnet thing worked. I fished around for like 15 minutes then all of a sudden *click*. I pulled it out slowly and there it was! What a relief that is... thanks for the help guys!
Old May 29, 2006 | 02:21 PM
Predator's Avatar
Thumbs up
That must feel good!!
Old May 29, 2006 | 02:31 PM
Gearhead1's Avatar
Lucky Bastard!! Nice save!!
Old May 30, 2006 | 01:18 PM
radkon's Avatar
We did the same thing on a buddy's cam swap but had to pull the head to get the damn thing out. Now we stuff the head bolt holes with paper towels before removing any parts of the valvetrain.
Old May 30, 2006 | 02:23 PM
vettenuts's Avatar
Stuff rags in all the holes before continuing, at least if you drop it it won't go in the motor.
