AFR 205s vs PRC/TSP LS6 CNC ported heads
I'd like to see RHS compared to an AFR head. The TSP head is a great deal and will produce good numbers. That being said the AFR is the better head. Its a money question. If you can afford the better head then you get it. The TSP is comparable, very comparable. I went with TSP for the money aspect. IF I get a chance to build a new motor it would be with AFR or RHS or ET heads.
