Torquer V.2 (cam inside)
Old May 30, 2006 | 01:32 PM
BLACKBIRD8200's Avatar
Default Torquer V.2 (cam inside)
How high are you guys spining your motor with cam?
I'm shifting at about 6300 but think I need to go higher?
Old May 30, 2006 | 01:41 PM
PREDATOR-Z's Avatar
6300 is peak, to benefit from a wider max hp range you need at least another 300 rpm
Old May 30, 2006 | 01:48 PM
so shift at 6600rpms and set rev limiter to 6700rpms?
Old May 30, 2006 | 01:49 PM
iamsickofitall's Avatar
my limiter was bumped to 6800 - i shift around 6600
Old May 30, 2006 | 01:53 PM
PREDATOR-Z's Avatar
Set limiter at 6900 and shift at 6600.
Old May 30, 2006 | 02:12 PM
GuitsBoy's Avatar
I shift 6600 and revlimit is set to 6800. Occasionally ill just brush against the rev limiter.
Old May 30, 2006 | 02:24 PM
Thanks guys
Old May 30, 2006 | 04:28 PM
MagiC5's Avatar
are any of you daily driving these?
Old May 30, 2006 | 04:33 PM
GuitsBoy's Avatar
I daily drive mine 80+ a day, through traffic, and i car pool with an old lady. Its nothing like stock drivability, but its not like driving a straight up pro stock race car either...
Old May 30, 2006 | 04:39 PM
Mine is only a weekend toy
how many have done rod bolts?
smokey1226's Avatar
can you discribe what you mean by nothing like stock drivability. Driving 80 miles a day leads me to believe its not too uncomfortable to drive in but something is missing?
Old May 30, 2006 | 04:48 PM
GuitsBoy's Avatar
Im fairly young at 25, and every waking moment is spent thinking about horsepower, so im willing to sacrafice drivability a little bit, but since i dont have alternate means of transportation, this one car must handle many tasks. It has to get me to work 3 days a week (the other two days the lady i carpool with drives), it has to be drivable enough that i can pickup friends and family and drive out to dinner without it being too embarassing. As it is, the bucking at low rpms is quite annoying and embarassing, however you can sort of learn to drive around it. Thats my main concern is the bucking, other than that the car is great. Bringing the compression back up has boosted the low end torque. Add enough timing at idle and right off idle and you can let the clutch out at 1000 rpm easily. However coasting and driving through traffic or at low speeds in a parking lot still prove troublesome. I find that I have to keep telling myself its a race car, drive it assertively, otherwise itll just sound like the car's broken. If youve driven old 60s or 70s muscle, youll have no problem, but if you want your car to be as refined as an audi or acura, it aint gonna happen.
Old May 30, 2006 | 04:49 PM
Tri5Nerd's Avatar
Default Good question
Just what he said, how many have changed thier rod bolts?
Old May 30, 2006 | 04:50 PM
GuitsBoy's Avatar
Rod Bolts? Not I. 2001+ cars got the stronger rod bolts from the factory, so im confident in them spinning to 6600-6800.
Old May 30, 2006 | 05:09 PM
NassyVette's Avatar
I DD mine and love it. I agree with GuitsBoy's description 100%. I have a QTP cutout and stock catback, as soon as I leave my apt. complex I open 'em up. Coming home, close 'em up.
Old May 30, 2006 | 05:10 PM
just1news6's Avatar
i have a 2000 you think i could spin mine to 6700 on revlimiter shifting at 6600 and be ok???
Old May 30, 2006 | 06:49 PM
1WICKDZ's Avatar
I have a 98, should I prioritize puttin some new rod bolts in soon.
