Setting adjustable rockers
Old May 30, 2006 | 02:23 PM
03BlackWidow's Avatar
Default Setting adjustable rockers
About to put the heads back on my car. I have comp's 1.85 adjustable rr's.
I've never set these before and looking for some tips. Its on a 98 C5 w/ ported LS1 heads.
Old May 30, 2006 | 03:06 PM
heavymetals's Avatar
Figure out how much one full turn moves the adjusting screw.
Adjust the rocker for "0" lash.
I use a felt marker to put a mark on the roller then adjust to the point where I can't roll the roller with my finger.
I use that as "0".
Then I just dial in the preload.
On mine (Comp Cams #1500) one full turn = 0.050"
Old May 30, 2006 | 08:09 PM
vettenuts's Avatar
With adjustables, your pushrod length will also determine your wipe pattern on the valve stem. Did you check this?
