60,000 mile tuneup/replacement?
Old Jun 1, 2006 | 03:28 PM
V8pwrdz28's Avatar
Default 60,000 mile tuneup/replacement?
didnt know which section to put this in really so just move it if need be please. im coming up on 60,000 miles here soon, what all should be serviced and/or replaced?
Old Jun 1, 2006 | 07:47 PM
V8pwrdz28's Avatar
anyone?
Old Jun 1, 2006 | 08:13 PM
redsscamaroboy's Avatar
My opinion is:
Air filter(if dirty)
Fuel filter
pcv valve
change trans fluid,new syncromesh(sp) will do good things for your M6
rear diff service
I hope your not still on the stock (factory) sparkplugs,they say 100,000 miles but i have never seen them work well to that mileage.( And i was a professional technician for 13years)
get some new Dexcool in that radiator(flush)
My not actually need all these things ,but your can not really over maintain your hotrod.
Drive it HARD and treat it well all at the same time.
Good luck
Dave
Old Jun 1, 2006 | 08:15 PM
V8pwrdz28's Avatar
dont know about the plugs if they are stock, but i was planning on changing them anyway. what exactly is the synchromesh?
Old Jun 1, 2006 | 08:49 PM
bmfcamaro's Avatar
a tranny fluid from GM
Old Jun 1, 2006 | 08:54 PM
V8pwrdz28's Avatar
ok had no clue what it was, thanks. how diffucult is changing the tranny fluid and what would a servicing the rear cost me u think?
Old Jun 1, 2006 | 10:36 PM
bene's Avatar
Trunion King
Changing fluids on tranny and rear is REAL easy. Alot easier compared to changing plugs and wires.
Old Jun 2, 2006 | 01:46 AM
Tram's Avatar
How is it changing the tranny fluid on the a4?
I just clicked over 60K and need to do some maintainence..
Old Jun 2, 2006 | 07:26 AM
slow trap's Avatar
just drop the pan,remove the filter and let it drain while you go to the parts store to get a filter which will come with a new gasket.i can't remember exactly but around 5 or 6 quarts should do it.i have seen some people remove the trans cooler line,start the car and let it pump dry like that and immediately shut it off when it runs dry but i wouldn't recomend that since you will probably need a new filter anyway.
Old Jun 2, 2006 | 08:18 AM
GuitsBoy's Avatar
You can get pennzoil synchromesh from autozone for much cheaper than at a stealership.
