New 402, 135-145psi on compression test?
The static compression ratio is 10.9:1, dynamic compression ratio is 8.1:1. I found an online calculator (http://www.rbracing-rsr.com/comprAdvHD.htm) that says my "dynamic cranking pressure" is 162psi.
Next Level Performance (who's tuning it) did a compression test, and got 135-145psi, across the board. That's with the engine cold, and no mileage on it yet, besides the dyno runs.
NLP thinks the compression test is low. FFHP (who built the motor) thinks it's nothing to worry about.
I know the cam overlap and late closing of the intake valve will bleed some pressure off, so I shouldn't expect as high of compression test results as a stock LS1. I also know compression tests give lower results on a cold engine. I do not know if the rings are fully seated, or if perhaps compression will go up after the rings are done seating.
Thoughts?
With the cam that's in there, if it's installed straight up (with the 2 degrees of advance that are ground in), the intake valve closes 73.5 degrees ABDC.
Dan
