Trick Flow LS1 head pictures inside
Old Jun 4, 2006 | 05:00 PM
2002_Z28_Six_Speed's Avatar
Those look like gems! I like the nested spring asm. Neat. Def worth the money. I might actually get those.
Old Jun 4, 2006 | 10:09 PM
JNorris's Avatar
Moderator
I am going to keep my existing 230/230 cam. The pushrods for these heads are 7.7 instead of the stock 7.4.
TEA told me that I will gain around .050 PTV clearance over my existing TEA 5.3 heads.
Originally Posted by exSSer
Beautiful looking parts. What cam do you plan on trying first? Also, what length of pushrod is need for these heads, and is there any PTV issues with the decreased valve angles? Good luck!
Old Jun 4, 2006 | 10:11 PM
JNorris's Avatar
Moderator
Originally Posted by Beast96Z
I know TEA moved locations to get in buisness with Trickflow. I wonder if they are actually using the TEA port in these heads?? BTW: the heads look great.
Good question. I will ask Brian or Mike the next time I talk to them.
Old Jun 4, 2006 | 10:30 PM
NoMoreFWD's Avatar
Originally Posted by StreetStalkerZ
Very nice looking heads. I'm impressed with the exhaust flow numbers
I always like Trick Flow's exhaust numbers. I would call it proper exhaust flow. These heads would rock with nitrous, turbo or supercharger.
Old Jun 4, 2006 | 11:53 PM
Beast96Z's Avatar
Like I said earlier, the exaust is flowed with a pipe, which will subsantialy increase the numbers. Removing the pipe should put them right in line, or maybe a touch above a normal LS based ported head.
Old Jun 5, 2006 | 07:08 AM
JL ws-6's Avatar
Race your car!
are the heads on a motor yet? Setup details, and results please.........
Old Jun 5, 2006 | 09:03 AM
JNorris's Avatar
Moderator
The current setup is TEA 5.3 stage 1.5 heads, a 230/230 LG cam, Edelbrock LT stepped headers (1-3/4 to 1-7/8) a TCI 4000 torque converter, 3.73 gears, LS6 intake. The race weight varies but is usually between 3380lbs – 3420lbs.
With this setup the car has gone high 10.90s in -1000ft DA air. In the heat it runs 11.20 to 11.30.
As of yesterday the TEA heads were off the car. I still have to clean the block before I can install the new Trick Flow heads.
The only change to the setup will be the addition of the Trick Flow heads.
John
Old Jun 5, 2006 | 09:22 AM
JZ'sTA's Avatar
Beast your correct. TEA/Trickflow are together now and Summit is in the deal somewhere as well.
TEA ports the heads for trickflow.
It is a new port design then what they have ever used before so this isn't just a good LS6 port thrown into a trick flow casting.
The heads are also a 13.5 degree head and will allow better then stock piston to valve clearence.
These are going to be some very nice high quality heads that should compete with AFR/ETP.
Old Jun 5, 2006 | 09:26 AM
JZ'sTA's Avatar
I wouldn't call it proper exhaust flow but only because of the pipe they use. I personially feel that a proper pipe would be about 30" long about 1 3/4-1 7/8 and have some clean 90% bends in the pipe so it acts like a header.
Most companies use a 10" or maybe a little longer straight pipe that is 2" or bigger.
That to me gives a false number.
I will agree however that a pipe be used
Old Jun 5, 2006 | 10:51 AM
ty_ty13's Avatar
7 Second Club
will TEA open up the combustion chamber for a large cubic inch motor?
Old Jun 5, 2006 | 10:57 AM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Cool
NICE LOOKING pieces there man...
Old Jun 5, 2006 | 11:38 AM
  #32
JZ'sTA's Avatar
I believe TEA will have some different options soon as though I am not sure what is available right now.
I have heard plans of a larger runner and different cumbustion chamber sizes so they can compete with all the different heads ETP offers.
Whenever I hear anything new I will post it up.
Old Jun 5, 2006 | 01:59 PM
  #33
Mike@TEA's Avatar
Yes. Also look for more programs to come in the very near future. We have a 225cc and a 240cc port for the larger engines that Brian is finishing the programs on right now. I will post more info on those soon.
Currently the TEA port is the Trickflow port or vice versa. Either way it's nice and the customer of either will benefit!
Old Jun 5, 2006 | 03:33 PM
  #34
MARKSZ71's Avatar
very nice congrats
Old Jun 5, 2006 | 05:23 PM
  #35
JL ws-6's Avatar
Race your car!
Has anyone had these heads flowed on an independant bench yet, and has anyone gotten them on a motor yet?
Old Jun 5, 2006 | 07:00 PM
  #36
Hardtop's Avatar
Mike I spoke to you on the phone about these heads, and am looking forward to some dyno results.
Bruce
Old Jun 9, 2006 | 10:01 AM
  #37
JNorris's Avatar
Moderator
The heads are installed. More info to follow.
John
Old Jun 9, 2006 | 10:10 AM
  #38
98Z28CobraKiller's Avatar
Restricted User
any seat of the pants difference?
Old Jun 9, 2006 | 01:11 PM
  #39
exSSer's Avatar
John
You're a tease.
Old Jun 9, 2006 | 04:00 PM
  #40
JNorris's Avatar
Moderator
I finished the install last night. The car started and ran well but it is still sitting on the jack stands. I still need to do some other work before it hits the street.
John
