DCR Calculation for a given Cam
Old Jun 4, 2006 | 06:19 AM
AJay's Avatar
Default DCR Calculation for a given Cam
Could someone please post the formula to calculate the SCR & DCR for the following LS1 engine.
Stock Pistons
AFR Heads Milled to 62cc
Stock GM Gaskets
218/224/114 cam
Thanks
Old Jun 4, 2006 | 08:49 AM
NoMoreFWD's Avatar
There is a calculator in the stickies on this page. Smokemup, a sponsor in the links on the right has a nice engine math section. You will need more data to accurately find your dsr.
Old Jun 4, 2006 | 10:39 AM
MSURacing's Avatar
Well, assuming a couple of things, your DCR should be right around 8.93. This assumes a seat to seat of 260 degrees on the intake lobe and a +3 on the pin angle.
Your static compression would be 10.9:1. If you can get me the intake actual duration and the installed angle, I can get you a closer number.
Old Jun 4, 2006 | 12:33 PM
AJay's Avatar
Thanks!
Would that info be available on the Cam Card?
Old Jun 4, 2006 | 02:04 PM
2c5s's Avatar
I get a DCR 0f 8.39 with zero advance ie 114+0 with comp lobes.
