If you had to pick a short block...
yea, a bigger bore would be better, but i still havent found a good reason to not put the biggest easily available stroke in there.
I have yet to see an alum block fail because too much power was being made. Sure, if you break a rod or whatever... but if that happens in teh iron block, you're just as fucked. Oh, and the price differnence beetween a 408 iron and a 402 alum, is 500 bucks. Figure out what you'll need to buy for LW parts to remove 100 lbs off the nose, ( assuming you have all the free removable stuff done, and now have to spend $ to get lighter ) and I promise, it's gonna cost you alot more then 500 bucks to pull 100 lbs off the nose. Hell, a k member is that alone, ad so are the lower a arms, and the LW brakes, are anywhere between 600 and 900, depending on which you go with, and all 3 are needed to remove 100 lbs from the nose.
Iron block guys won't agree... but this is the facts.
Personally, I was gona build an iron block setup, but changed my mind due to the weight, and am not gonna rebuild my alum setup.
I will have a freight scale in another week or so and I will try and weigh them both for real for you guys.
All the points you make are valid ones from what everyone has told me, yourself included, but for the goals that I have and the power I plan to make, the reduced weight will be more of an advantage then the iron block stability.... when you're only trying to make 500 rw on motor and about 650 give or take on the gas, I don't think I'm pushing the alum block to a point where the block strenth is going ot be an issue.
for those of us who already have nose-heavy cars, the extra 100lbs of the iron block just is not the best option.
