Old Jun 5, 2006 | 05:42 AM
Fast GTO's Avatar
Default 228/232
How much power do you think this cam will make with full exhaust and a decent set of heads?
278*-228*-.598"
282*-232*-.598"
114* LSA - 111* ICL
I am running an automatic which is why it is on a 114 LSA.
Old Jun 5, 2006 | 05:53 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
385-405 for an A4 car.
Old Jun 5, 2006 | 07:13 AM
cenTX-LS1's Avatar
With heads I would think it would do a bit better than that.
Old Jun 5, 2006 | 08:55 AM
RoastEmSS's Avatar
with LS6 intake 405-410 rwhp. If it was an m6 415-420rwhp. It will have very nice power under the curver, but it wont peak as high, itll also have nice torque curve so get it
Old Jun 6, 2006 | 05:29 AM
Fast GTO's Avatar
That is exactly what I was hoping to hear...power under the curve is where it is at with a nice amount of torque!
Old Jun 6, 2006 | 06:34 AM
PREDATOR-Z's Avatar
The 114+3 (111 ICL) has a 53 EVO which is a short stroke and won't be that good on midrange trq.
Preferable is 112+1 with 49 EVO
But if it was me I would get it on a:
111+1 (110 ICL) for a 48 EVO thus more trq in midrange, still carrying well (4* equidistant IVO/EVC from TDC) after 6300 peak (44 IVC) and a nice 8* overlap (good lope)
With todays HP tuner capabilities, running it on A4 will not be a problem in the hands of a good tuner.
Old Jun 6, 2006 | 06:50 AM
Fast GTO's Avatar
Sooooo your saying it won't have a good midrange compared to other cams like a 228/228 or 224/224?
Old Jun 6, 2006 | 01:05 PM
PREDATOR-Z's Avatar
Yeap!! compared to a 224
See, to make power in a certain rpm range you need certain VE's (valve events), now to make more power in the same range with bigger duration cams, you need to increase SCR and DCR (static and Dynamic compressions) witch can be done by smaller head chambers and gaskets, or by going tighter LSA/advance, or both (then you just have a optimised combo )
Old Jun 6, 2006 | 02:54 PM
Fast GTO's Avatar
I have 64.5cc Chambers and slightly milled heads (very slight).
Intake:
.1---87.5
.2---157.7
.3---231.2
.4---266.6
.5---289.1
.55--301.8
.6---299.2
.65--298.9
Exhaust:
.1---68.3
.2---107.7
.3---161.1
.4---194.8
.5---216.5
.55--222.3
.6---231.5
.65--231.2
Old Jun 6, 2006 | 03:51 PM
Ed Curtis's Avatar
Pred...
Same cam profile on a 111* +2* using the same style PPFL heads had major P/V issues and could not be used. That's a reality that a computer program can't take into consideration when they spit out cam specs.
Also keep in mind, the latest "trend" on this site for tighter LSA cams is actually old news. The timing events I used on many street oriented 302 Fords (and LSX cars) resulted in even tighter LSA profiles than seem to be in vogue over here. Ask J-Rod about that if you don't believe me. Like I said, there's more to this cam stuff than what some program says. All parameters must be considered... Like... if the cam even fits!
Ed
Old Jun 6, 2006 | 05:38 PM
redtail2426's Avatar
who makes that 228/232 ??
Old Jun 6, 2006 | 10:14 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Thunder or TSP can probably custom grind one with those specs if they arent the one that makes it already. Might be a Futral cam.
Old Jun 7, 2006 | 01:42 AM
PREDATOR-Z's Avatar
Originally Posted by EDC
Pred...
Ed
That I know Ed,
I my part of the world, I'm blessed with being outside the box (US) mainstreem and I'm also exposed to Aussie thinking.
Say less than 110 LSA 2 years ago and you are laughed at.
You know better than me, that putting specs on a cam doesn't necessarily means it is going to behave exactly that way in the motor it is going in.
But the basis is there.
That is why I'm not a big fan of advance in cams, straight up is the way to go, then tweak it on a dyno via advance/retard and timing.
Otherwise, Ed there will be no biz for "custom" cams, but that is part of modding and innovation.
Look at cam mainstream itself, it is changing. Less fear of big lifts, tighter LSAs are just "part" of what is there to play with.
The "perfect" cam only exists within the parameters it fits at actual time of grind and application. Deviate from that and the "recipe" will require more "salt" and/or "pepper".
We all have "our" trends, J-Rods, 53pony, yourself have yours. I just wish I had the ability to implement and test mine with the wide range of resources you all have.
But that is what makes you guys "GURUS" and me an amateur, right
And the other difference is obvious, what I learn, I share, and what I share it is for free
I like when you three get into discussions, I miss that.
Old Jun 7, 2006 | 06:50 AM
Ed Curtis's Avatar
Cool
That I know Ed,
Some laughed at it, some laughed at those laughing at it.
Yup.. 100% on the mark.
I've noticed a few things on street cars when manipulating the ICL a little. I guess it stems from testing on the track vs the dyno.
Yeah but from my "dumbass" standpoint, there's a place for everything. When it's an oddball application or a mixture of "certain" parts, only a designed camshaft will work. When a "package" of goods is sold, then a "shelf" grind, based on the package is still a good move. I could get into more but I'm on K.P. over here.
The big lift lobes are a direct result of needing more lobe area all while trying to avoid big duration numbers. Those "square" lobe grinds that just add more and more duration with no change in lobe lift are valvetrain killers. Can you say NHRA Stocker grinds?
That's a quote that "signature" worthy...
All it takes is money...
That type of discussion won't happen here anymore... Shaun and I are on the "list" so you'll have to visit hardcore50 or the other site if you want to see that happening again..
I'm outta here before I'm executed...
Ed
Old Jun 7, 2006 | 06:51 AM
Ed Curtis's Avatar
Cool
None of the above..
Ed
Old Jun 7, 2006 | 04:46 PM
so............is this an Ed Curtis cam?
Old Jun 7, 2006 | 05:10 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
None of the above..
Ed
Lol!!!
